Del key input ('X) closes down program
Hi,
I just want to delete the highlighted item but for someone reason, if there is no highlighted item, 'X causes the program to shut down (as if I hit Close or Ctl-Alt-Del).
Any ideas?
Thanks so much,
S
are you using ctl-alt to trigger the macro?
sounds like it's picking it up during the actual trigger.
An old blog on QM coding and automation.
The Macro Hook
That's exactly right. Let me go change the trigger!!!!
Stuart
From my experience, only Ctrl+Alt in trigger can interfere with Delete in macro when Eat is checked. To avoid it, check When Released. I don't know other unsafe key combinations.
