Threads: 21
When I press the "convert V1.x macros" button and run it on my old V1.3 LIST.INI file, it says "CANNOT CONVERT". I have installed version 2.09 on 2 different computers and the convert function does not work on either. What have I done wrong? Grateful for help.
When you try to convert QM1 macro list file (List.ini) to
QM2 format, you may get "Can't convert" error.
Currently, conversion function has bug: if List.ini file
contains non-ASCII characters, it fails.
Now this bug is fixed, and zip file is updated.
Threads: 21
Thanks for the quick response. The macro you sent me successfully created LIST2.INI as you explained. However, when I opened one of the old macros and then pressed SHIFT F8 the response was Error in CM_Main: unknown identifier. What next?
By the way, here in Norway we don't use the folder PROGRAM FILES. We use PROGRAMFILER. I changed that in your macro. I also run QM-2 under PROGRAMFILER.
The non ASCII characters that we use all the time here are Ø,Æ,Å. Will that be a problem with QM-2.09, which I have installed now?
