REST API calls
Can quick macros make REST APIĀ  GET/POST calls?
Quick Macros has internet functions, but no JSON functions. I recommend to use LibreAutomate instead.
Thank you for your quick response. Do you have an example of a REST API call for LA?
@jimmie48jj
Http post web form, JSON | LibreAutomate
If you have LA, look in its Cookbook panel.
https://www.libreautomate.com/cookbook/H...0file.html
https://www.libreautomate.com/cookbook/H...0JSON.html
LA uses C# and .NET. On the internet you can find many C# examples of REST API call.
