Threads: 293
06-06-2025, 11:11 AM
(This post was last modified: 06-06-2025, 11:13 AM by Davider.)
Is there a simpler way to write an array of variables of the following variant types?
The following code works, but I think it's neither elegant nor concise.
Thanks in advance for any suggestions or help.
Function arrVar
function` [`_A1] [`_A2] [`_A3] [`_A4] [`_A5] [`_A6]
ARRAY(VARIANT) args.create
sel getopt(nargs)
,case 1 args[]=_A1
,case 2 args[]=_A1; args[]=_A2
,case 3 args[]=_A1; args[]=_A2; args[]=_A3
,case 4 args[]=_A1; args[]=_A2; args[]=_A3; args[]=_A4
,case 5 args[]=_A1; args[]=_A2; args[]=_A3; args[]=_A4; args[]=_A5
,case 6 args[]=_A1; args[]=_A2; args[]=_A3; args[]=_A4; args[]=_A5; args[]=_A6
How the array will be used? Should it be standard QM array, or need SAFEARRAY like in CsFunc? Or maybe just VARIANT* (then it's &_A1).
Threads: 293
06-06-2025, 12:24 PM
(This post was last modified: 06-06-2025, 01:07 PM by Davider.)
Used in scenarios like the one below
Function arrVar
CsScript x.AddCode("" 0x10000)
sel getopt(nargs)
,case 1 args[]=_A1
str command=
;cd
ret x.Call("test.Call2" command args)
#ret
public class test
,public static string Call2(string command, params object[] args)
,,Console.WriteLine(command);
Quote:SAFEARRAY like in CsFunc
I tried, but had no luck.
Quote: VARIANT* (then it's &_A1)
That should be the idea, but I don't know how to modify the code.
The following code throws an "invalid type cast" error at runtime.
06-06-2025, 01:23 PM
(This post was last modified: 06-08-2025, 05:31 PM by Gintaras.)
Function VariantArgsToArray
function ARRAY(VARIANT)&a VARIANT&firstParam nParamsBefore
;Creates ARRAY(VARIANT) a and moves VARIANT parameters of the caller function to it.
;a - ARRAY(VARIANT) variable. This function creates the array.
;firstParam - address of the first VARIANT parameter.
;nParamsBefore - the number of function parameters before the first VARIANT parameter.
;EXAMPLE
;function` $name [`_A1] [`_A2] [`_A3] [`_A4] [`_A5] [`_A6]
;ARRAY(VARIANT) a; VariantArgsToArray a &_A1 1
int na = getopt(nargs 1)-nParamsBefore
a.create(na)
if na>0
,na*sizeof(VARIANT)
,memcpy &a[0] &firstParam na
,memset &firstParam 0 na
Function arrVar
CsScript x.AddCode("")
ARRAY(VARIANT) a; VariantArgsToArray a _A1
str s=
;cd
ret x.Call("test.Call2" s a)
#ret
using System;
public class test
,,Console.WriteLine(command + ": " + string.Join(", ", args));
,,return null;
Macro Macro3503
Threads: 293
06-06-2025, 01:47 PM
(This post was last modified: 06-06-2025, 01:51 PM by Davider.)
Thank you so much!
The code is much more elegant now and supports more parameters.
is there a way to make the function return a variant type?
public static object Call2
Threads: 293
Thanks again!
I can finally enjoy seamless interaction between QM and C# code.
